Some covers will be displayed, other won't
    Hello Guido,
    Sounds like there's a bit going on here. Since you've already gone through some of the troubleshooting steps, I would recommend sending support@bluesound.com a screenshot or a zipped folder of one of the albums where the cover art won't display so they can test it on their end to see what's going on.
  • Markus Steiner
    is there a solution? having the same problem, appr. 50% of my albiums dont show a cover,
    was already wondering if there is an option to upload them manually to bluOS like eg in itunes
