Connect Node 2i to a cd transport
BeantwortetHi,
I have a cd player and I want to use the node 2i as a dac (to use the cd player as a transport).
The cd player has a spdif coax digital out.
Which cable do I need to use in order to connect it?
I understand that the device has analog/digial toslink output, but how can it go with one side spdif coax cable?
Now I currently use the cd player's dac by connecting it througe the rca out to analog in (in the node 2i), but I really like to try and use the cd player as a transport.
Hello Chen,
This wouldn't be easy to do, as Coax uses conductor wire to transmit electrical data, whereas Optical transmits using light.
You would need to purchase a third-party SPDIF to Optical adapter for this purpose, though I have not done any testing and cannot make recommendation on any specifics.
Sam R. -
Thanks Sam,
Do you think I will benefit from this sound quality-wise?
Difficult to say. Usually comparing DAC audio can really only be done by actually listening to both back and forth -- it comes down to how it sounds to you (quality could be the same but DAC sonic signatures differ; some have a warmer sound, some are more neutral, etc).
Also, I'm not sure how much the digital audio quality will be affected after going through a Coax to Optical adapter.
I would recommend purchasing one of the adapters from a place you can be sure to return to, and then comparing both the Node's DAC vs your CD player's DAC so you can confidently decide which you prefer sound-wise.
Sam R.0
