Connecting a Node2i and Flex 2i
    Hello,
    If you would like to stream from the SSD connected (via USB) to the Node to a Flex, you would need to group them together for the Flex to be able to access the Library on the SSD. Grouping can be done on WiFi, but I find as this is a more bandwidth-intensive process using Ethernet on at least one of the players provides a more solid experience.
    That being said, you can alternatively connect this SSD to your router and essentially create a NAS. This way, the Node and Flex can both be pointed to the makeshift NAS and stream from it. In this approach, you wouldn't need to group the players, and so if WiFi works well as it is you can stick to WiFi.
    I would recommend the second method as it's overall an easier experience.
  • Bisscom
    Thanks Sam for the info. It looks like i will be able to achierve what i need to do. Cheers, Si
