  • Bert
    I am also the second owner of a N150. During the last update of the firmware the N150 stucks up with a red light. It will not reboot anymore by USB or LAN. The wireless function has failed a few months ago. Since then i have used an Apple airport as a kind of accespoint. It worked perfect but now I’m afraid I can send it to the trash.
    Hope that someone has some suggestions.
  • Sam R.
    Hello Bert,
    If possible, I would recommend running a LAN cable from the Powernode directly to the router temporarily to see if that allows the update to go through.
    That being said, if there's no light, you could also look into replacing the power cable to see if that catches it.
  • Robert Jennings
    I can see a green led inside through the mesh but no light on power/boot button. Seems dead.
