NAD T778 and Bluesound
BeantwortetHi Guys,
It's Richard at Audiologica in the UK. I have a query on the T778 and Bluesound - (unfortunately we don't have an in-store model due to low stock availability in UK)
My question is, is Bluesound embedded within the amp? So will Bluesound work when simply connecting an Ethernet cable to the amplifier or does the supplied dongle also have to be connected?
Just to be clear - we are talking about connecting the amp hard-wired via Ethernet and not via wireless...
Kind regards,
Richard
Hello Richard,
We've responded to your original email request -- if you don't see it in your inbox, please check your junk folder.
Sam R. -
Hi Sam,
Excellent - many thanks!
Richard
Hi guys, I'd like to know the answer to this question too - can you let me know please.
Hi Paul,
Yes it will work with a Ethernet cable - no need for the module.
Richard
Audiologica Ltd
Thanks Richard - thats great - saves more stuff plugged into the back!
5 Kommentare
