Lip-sync issue – request for low-delay mode to watch videos
Lips of actors and audio is clearly out of sync while watching videos on Powernode 2i and Node 2i. We have tried both minimum "Lip-sync delay" with "A/V mode on" and "A/V mode off", in the second case delay became even worse.
I tried to use "audio bypass" mode and all possible "A/V sync adjustment" values on my TV, it doesn't fix the lip-sync issue.
Your products are having HDMI interface onboard and is clearly intended for use with TVs, but lip-sync issue is ruining the experience.
In my case only thing that changed and causing delay is Powernode 2i, in fact it's the only thing in my audio chain: TV ARC -> Powernode 2i -> Focal 806 (speakers).
A/V mode description states: "Enabling A/V mode helps with real-time audio (such as TV synchronization) ... Disabling A/V mode prefers quality over speed and is best for audio-only sources"
So when A/V mode is enabled, speed preferred over quality, but artificial delay with 50ms minimum is added.
To deal with lip-sync problem we requesting to have interface-wise low-delay mode with speed preferred over quality without artificial delays. It is ok if groups will be disabled or some other restrictions will apply for this mode.
Your concerns have been addressed here; https://support1.bluesound.com/hc/en-us/community/posts/360046724114
Thank you for your patience and understanding.
This absolute must for standalone use.
4
