RCA cable upgrade?
BeantwortetI have the Node2i connected to my pre-amp using the supplied RCA cables. I also have some thicker gauge/ higher quality cables available. I'm wondering if there's any benefit or downside to using them?
Hi Tom
When it comes to the value of cable quality, that's for YOUR ears to decide...
The sound part I can figure out. I was more questioning whether putting a a larger cable on it would have some negative impact or some measurable improvement to the equipment .
