flashing optical output and ethernet
BeantwortetWoke up this morning with the Node 2 having a solid red light on front. Let it sit for a while and started to investigate. Powered down and back up. Connected directly to the modem. Tried to do a manual update. Nothing works. All I get is a blinking red light in the optical output (no connection), blinking light for the ethernet (no connection), and solid red light in front. Any thoughts?
Hello David,
Sorry to hear you are experiencing issues with the Node 2 in solid red after your aforementioned troubleshooting.
Please contact our support crew directly at support@bluesound.com so that they may investigate the case further for you.
