Playing TV Sound on PowerNode 2I with HDMI
BeantwortetHello,
I bought a Powernode 2i (with HDMI) and connect it to my TV whitch is compatible HDMI ARC with HDMI cable.
When i turn on the TV the sound from the TV sometimes don't play immediately. I have to wait for long time to have the sound. Suddenly the sound come without explanations
I don't know what to do....
Thanks
Hi Vincent - if the timing is consistently about 6 seconds (give or take) it is the amplifier waking up from deep stand by. You can disable this by selecting Settings, Player, Amplifier Stand By ad setting it to off in the App
Hello Tony,
Thanks for your answer. I'll try your solution. I'll get back to you soon...
Hi, I have a related question. I consider bying a Powernode 2i (replacing a Node 2). Does the Powernode 2i automatically switch to HDMI ARC when the TV turns on, even if it is playing from another source? Will it wakeup and switch to HDMI ARC even if it was turned 'off' when using another source?
Hi Sebastiaan - The POWERNODE 2i w HDMI does support auto-sense
4 Kommentare
