Auto stand-by with analogue input
BeantwortetMy Node 2i does not auto standby when the analogue input is selected. The source (an AVR) is switched off... Auto stand-by does work while using the Node 2i with Spotify direct
Hi Hessel
Your node is still picking up noise from the analogue source. Consider choosing a different cable perhaps. That or your AVR may have an inaudible ground loop happening to create the noise.
