Power Node 2i as Node 2i
BeantwortetCan the Power Node 2i be used as a Node 2i, as a streaming player source without using the amps and speaker outputs? My current receiver is old but still working. So I wanted to use the Power Node 2i and a streaming input and then if my receiver dies, I'd use it in it's full capacity.
Hi Steve
No - The POWERNODE does not include any pre-outs.
Makes sense. Thank you. I should have looked a little deeper.
Is HDMI eARC not bidirectional?
Hi Janos
The POWERNODE does not support eARC.0 -
Hi
POWERNODE 2i (with HDMI) is supported as officially described.https://www.bluesound.com/products/powernode/
I have misunderstood something?
Hi Janos
We are looking into the conflicting specs.
We do support 24/192 playback and meet the audio playback aspects of eARC. However, the POWERNODE and PULSE SOUNDBAR only receive audio but do not transmit audio over HDMI so are not bi-directional.
Thank you for your information. That might be a good direction for development. You could take full advantage of the technical possibilities of eARC. ...
7 Kommentare
