When accessing the vault through my network, I see 2 folders "a-ha" and "a-Ha" which act are identical
    Wesley P.
    Hello Cedric,
    What you have noticed is a discrepancy due to the Vault running a Linux based system and your computer running Mac or Windows. Since Linux is case sensitive, the folders a-ha and a-Ha are seen as 2 completely separate folders to the Vault. However, when navigating through the internal storage on your computer, your computer sees these 2 folders as the same directory.
    To resolve this, I would suggest renaming the folder you would like to get rid of as "a-ha 1" to allow your computer to recognize it as a separate folder. After doing this, you can transfer the contents of one folder to the other and delete the emptied folder to help consolidate your music library.
    I hope this helps to clarify what you are seeing.
    Wesley P.
  • Cedric Barra
    Thanks Wesley. What you describe is not exactly the issue I had (for me it was the opposite: the Vault saw only one folder, but I could see 2 in macos). However I did follow your suggestion to rename 1 folder, and deleted it. That did not do anything to the other folder. Things are now correct even after an index rebuild.
    So thanks !
