Node 2I and wireless amplifier
BeantwortetHi,
I just bought a node 2i and would like to add my external pasive speakers to the system. I was wondering if there is a wireless amplifier (like sonos has for example) that can include in the node 2i system to send music to that amp. Thanks in advance.
Hello Jor,
From what you have described, you are looking for a Powernode 2i. The Powernode 2i has very similar features to the Node 2i, however, it includes an internal amplifier to allow you to connect directly to passive speakers.With a Node 2i and Powernode 2i in your home, you can seamlessly play music to each or both player simultaneously using the BluOS app.
Wesley P.
