Bluesound Node 2 - Analog input sound glitch and then delay
BeantwortetHi,
My bluesound Node 2 sometimes make a small glitch/notch when using Analog Input from my TV.
After this happens the sound is delayed by something like 500ms.
If I then pause and start the analog input again everything is working fine and there are no delay again.
This happens randomly. Sometimes multiple times each hour, sometimes not in a whole day.
Anyone who have had this issue also?
Regards
Kenneth
Hello Kenneth,
I'm sorry to hear you're experiencing issues with your Analog Input. The next time this issue occurs, please send us a diagnostic log from your Node 2 by going to Help > Send Support Request. The log will be included automatically with your request and a member of our support crew will review it and work with you to resolve this issue as soon as possible.Regards,
Wesley P. -
Hello,
Sorry for reviving an old thread, but did you ever find a solution to this? I'm experiencing the (seemingly) same issue.0 -
Hi Viktor
Too many unknown variables for a general why. Please select Help, Send Support Request so we may see the log file for a closer look.
Hi Tony
I know, I've sent a support request as well. I was just curious as Kenneth's description of the problem seems to match mine exactly, and perhaps, if the problem is the same, the solution could be as well1
4 Kommentare
