NAD c368 MDC bluos 2i quality
BeantwortetIn the NAD spec sheet of the module it says it has an APTx connection through Bluetooth devices. I am wondering, if I have the module connected to the network and use my android to stream MQA quality music from Tidal, will it be limited to APTx quality or will a be able to get the full 24/192 quality?
Also, is there a difference in quality between a WiFi and Ethernet connection?
Thanks
Diego
To receive full MQA Quality in TIDAL, please use the BluOS App to control your NAD C368.
Otherwise, you will only receive the upper limit of your handheld device.
Thanks for your reply. Just to be clear, it doesn't matter wether I am using WiFi or Ethernet connection on the mdc module?
Hello Diego,
To clarify, there will be no change in audio quality between using an Ethernet or WiFi connection to your network.
Wesley P.0
