RCA + Coaxial
    Wesley P.
    Hello Arun,
    The Node 2i is designed to provide audio through all the available outputs on the back of the player simultaneously. This means you should have no issues connecting multiple devices to these outputs at the same time. Even with both coaxial and RCA connected at the same time, each will provide audio independently with the coaxial output bypassing the internal DAC and the RCA output being processed by the internal DAC.
    Wesley P.
  • Arun Unni
    Thanks, this helps. When I've connected both in the past, I have struggled to hear the difference between the RCA and coaxial to another DAC, which led me to believe that the Node was somehow processing both similarly. Dont know enough of the tech to understand if thats possible. This clarifies.
