bluesound fix &veriable
Beantwortethi all
in the menu we can chose between VARIABLE and FIX
but we have only 1 rca t ?
in denon and marantz its different
Hello Shay,
You are correct that devices developed by different manufacturers may operate differently. Since you have not mentioned which Bluesound or NAD device you are using, I can not provide you with any specifics. However, by adjusting the setting for Fixed or Variable output, the output of that device will reflect this setting.Regards,
Wesley P.
