Can I download my BluOs Library to an SD card for use in a Hi-Res portable player?
BeantwortetI love my Vault 2i - but like others I would like some quality music on the go. I am currently looking for a suitable Hi-Res player - and would like to download my Vault Library - in FLAC format - to an SD card which I see many of the portable mobile players use - as the storage for their music library.
Currently, my mobile played is an ageing iPod Classic - which I want to upgrade considerably from - and as I say - access a higher quality resolution for my music library to play on it.
Any suggestions or helpful tips - gratefully appreciated - thank you in anticipation.
Hello Stephen,
If you would like to transfer contents from your Vault to other devices, you will first need to access the Vault's internal storage from a computer on your network.https://support.bluos.net/hc/en-us/articles/360000480068
Once you have access to your Vault's internal storage, you can freely transfer any music you wish to any of your external devices such as an SD card.
Wesley P. -
Hi Wesley,
OK - thanks for the link - I will certainly follow that closely - now all I need to do - is decide on a suitable player!
Regards, Steve
