    Wesley P.
    Hello Peter,
    From the path you provided, it appears you are connecting this share from a connected USB drive and not directly from your computer. The first thing I would suggest is to verify the sharing permissions on your LaCie drive to ensure Guest users are able to connect to your iTunes folder.
    As for your file path, you should be using the syntax of \\Computer Name\Folder Name. This means if you are sharing the iTunes folder on your LaCie drive the path should be \\Computer Name\iTunes.
    If you continue to experience issues connecting this share, please send us a diagnostic log by going to Help > Send Support Request and our support crew will gladly look into this further for you.
    Wesley P.
