best nas for node 2i
Beantwortet4 Personen folgen
What is the reccomended NAS drive to use with the Node 2i, or which NAS should be avoided?
Hello Rich,
We can not make any direct recommendations for equipment not designed by Bluesound. However, what I can suggest is to ensure that any NAS which you purchase supports SMB sharing as this is how BluOS connects to external libraries. If your NAS supports SMB, you should have no trouble connecting your library over your home network.Regards,
Wesley P. -
- On Synology NAS
- Go to Control Panel-->File Services
- On the SMB/AFP/NFS tab, select Advanced Settings
- Change Maximum SMB protocol to SMB3
- Change Minumum SMB protocol to SMB2 with large MTU
SMB1 is nog longer supported.
