Mini2i and Turntable: low volume
4 Kommentare
    Hi Marco
    It would be in the output of the turntable. Check your documentation to see if there is a gain setting on the turntable you can boost - that or ensure the cartridge is installed properly. Perhaps you would need a higher mV rating on the cartridge. Check and see what Rega has to say.
  • Marco
    thanks for your answer, unfortunately there isn't any setting I can tune on the turntable: the Carbon cartridge that comes with it has an output of 2.5mV at 1kHz. Is it too low? Is there any recommended mV rating to play with mini 2i?
    Thanks!
    Hi Marco
    I can't answer that because it depends on the phone pre-stage and how many volts they supply to the gain which is in the turntable itself. That is a question for Rega I am afraid.
  • Marco
    Thanks for answering, I'll get in touch with them!
