Add audio track to playlist
Hi,
I'm trying to add an audio track to a playlist. Nothing happens. It is not possible to add.
Hi Domanin
I have been able to replicate your issue here. I suspect it has to do with the fact the song is stored on a USB Drive and reporting it to our QA team for further investigation. What I would suggest though is rather than plugging your USB Drive into the Player itself, you may have a better overall experience plugging the USB Drive into your router and creating a file share with it; https://support.bluos.net/hc/en-us/articles/360000465747
You will not have to unplug it form the player to add music from a PC to it and you will have a permanent Local Library this way too. Check if your router has a USB drive and plug it in there and connect under Settings, Music Library, Network Share in the BluOS App; https://support.bluos.net/hc/en-us/articles/360000469948
Thanks to Tony for your prompt reply.
I know the idea of a router. I can buy NAS server "Synology" or another good router, but I want it to work from usb hdd.For information, my usb hdd is 4 TB and it has 100,000 audio tracks. The BluOS works great. Maybe someone will find this information useful.
I made these screen shots with NODE 2i, today I bought NAD M10 for 2999 euro, the situation with the playlist is still the same.I think need to fix the firmware, it is important for us buyers.
Hi Domanin
The NAD M10 uses the same firmware for the most part. As mentioned in the first Help Centre Article I posted, there is no fix coming as it is by design. We cannot guarantee it's always the same USB plugged in so have to assume it is different anytime.
