Reset volume level after some time
BeantwortetHi
I would like a feature that resets the volume to a default or user set value after the bluesound device have been inactive for some time (e.q. 30 min). At the moment the device seems to output last volume level, which is some cases can be quite overwhelming (loud)!
Thanks for the feedback Thomas - I have passed it along for future consideration
many receivers have a setting where you can set a "power on" volume setting so that no matter what volume you were at when you you powered off, you can have a safe volume level when you power back up. I would expect this to be pretty straight forward to implement.
