Connecting TV with 3.5m jack or digi coaxial
    The headphone jack will work but not ideal... I had a similar problem back when the original PULSE came out. You can get a COAX to TOSLink adapter on Amazon or at a local consumer electronics shop. They usually run in the $30-50 range for a half decent one and will require AC power generally...
  • Mark
    Great. Thanks
