Sound suddenly stops
BeantwortetI have the Powernode 2i connected to the tv via HDMI
I have the Powernode 2i connected to the internet via Wifi
I was listening to music all day and there were no problems.
I switched to the tv to watch a movie, 40 minutes into the movie we heard all kinds of scratchy noises and then the sound stopped. The blue light is still on. I opened the app and saw it didn't show any players anymore but 5 secs later they all appeared again. Still no sound from the tv though. I had to turn off the tv, switched the powernode between HDMI, Bluetooth and back to HDMI and then when i turned on the tv again the sound was back. But every few seconds you can hear some cracking noises softly.
Can someone please explain what the issue is here?
- We can still return it for an other one (it's a week old), so if it's factory issue i would really appreciate the honesty. (I've had my fair share of faulty receivers, not looking for this again)
Please select Help, Send Support Request so we may see what is going on. If there is a physical fault it is most likely the cable and not the TV or the Player. Chances are it is a software setting. Sending a support request will send us the log file to better find the root cause.
