    Wesley P.
    Hello Guy,
    Depending on the model of B&W speakers you are using, the way to connect these speakers may be different. Due to the Node 2 not having its own internal amplifier, you will only be able to connect active speakers directly to the player. However, if these B&W speakers are passive speakers (similar to the ones connected to your Powernode 2) then you will require an amplifier to power the speakers connected to your Node 2.
    Wesley P.
  • Guy
    me previous node 2 speakers were JBL wifi speakers. I could connect the transmitter to the RCA's on the node 2. The JBL's are now dead.
