I lost my privileges to write on Vault from Mac
BeantwortetHi,
I try to load FLAC files from my MAC to my Vault.
It worked perfectly fine until recently.
I changed internet provider, and it now says in the Finder that I don’t have the rights to Import/cancel/modify files on the Vault.
Can you please assist?
Thanks and regards,
Jérôme
Hi Jérôme
I am escalting this issue to our Support Crew as they will need to connect to your VAULT. We will be in touch soon.
Thanks for your patience.
Tony
