Volume difference
BeantwortetHello,
Today I tested my Bluesound Node 2 player, a Raspberry pi with Volumio with Allo DigiOne spdif output and a Windows PC with JRiver and Topping D10 DAC as USB spdif converter.
Why does the Node 2 player plays around 3 dB louder?
Does the Node 2 shifts bits in the spdif?
I compare the systems by a remote spdif switch, due to the output difference this is very difficult to judge for the Node 2.
I am very curious how this is possible.
Kind regards,
Hans
We don't up sample, we don't down sample and we don't volume shift unless you enable tone controls. Enabling Tone controls will have a 6db shift but that is down in volume to ensure head room to bring up treble or bass...
I cannot explain the results you are getting - but as always, let your ears decide.
