Bluetooth headphone setting
BeantwortetI have a Vault 2i which is connected to my stereo via the optical cable. This works fine as is. I also have Bluetooth speakers out by my pool. I can connect them using the Bluetooth headphone selection, but this then cuts out the optical connection. Is there any way to do both at the same time, or is it one or the other?
Hello Jim,
When enabling the Bluetooth headphones option in the BluOS app the other outputs of your 2i player will be disabled. This is because when listening with Bluetooth headphones it is assumed that you do not want to have audio continue to play out of the main speakers of your player as well.With that being said we have received similar feedback from other users connecting their 2i device to an external speaker and we have passed this information along to our Quality Assurance team to see if we can allow the main outputs of your system to persist even when connected to a Bluetooth output device. Unfortunately I do not have any further information on if or when this feature will be released into the BluOS app but rest assured we are looking into this possibility in a future firmware update.
Wesley P.
