7 Kommentare
    Hi Denolletjes
    No - you will have to switch sources in the App. You can program a preset to make this easier and when you turn off the TV press the preset on your TV remote.
  • René
    Thx Tony
  • ASGHAR shah
    Tony,
    when I connect my LG TV C8 with optical in , but when I use the optical out to connect to my PS audioDirectStream DAC i do not get any sound although the red light is their ?  Basically using Toslink from TV to Bluesound Node 2i and from Node2i to DAC it should work should it not ?
    It should - please select Help, Send Support Request so we can get more details and see the log file...
  • ASGHAR shah
    Tired once again had amazon Tech work with me for over an hour no results returning the unit and re ordering from Amazon to see if the new unit will not have the same issue
    Hi Asghar
    I have opened a Support Request with OUR Support Team... the issue is not hardware related and we will be happy to help walk you through it...
  • ASGHAR shah
    thanks
