Bluos Controller on Mac not finding Pulse-Flex
12 Kommentare
    Hi Julian
    Band spanning is not an agreed upon industry standard...   ...yet. British Telecom (and Bell Canada too so not picking on anyone) has some weird rules on how they invoked it. Check out; https://support1.bluesound.com/hc/en-us/articles/115005578588
  • Julian Redding
    Hi Tony, thanks for coming back so promptly. I suspected as much. Unfortunately, the BT Smart Hub 2 does not allow you to split the bands as you could do with previous models of the BT Hub.
    I'll speak with BT and get their take on a solution (if any) and report back.
  • Julian Redding
    And there is no solution for a BT Smart Hub 2. Band spanning or steering can't be turned off.
    FYI - everything works fine on IOS. Just seems to be an issue with the Bluos Controller App on Mac OS (Mojave).
    Hi Julian
    Please select Help, Send Support Request - we would like to see your log file and our Support Crew may have some other tips to help.
  • Julian Redding
    Hi Tony, that option is not available on the Mac OS version. See attached screenshot.
  • Julian Redding
    Or it doesn't connect to allow me to do so!
    Julian
    Are you stuck on this black screen? If so, please drag the App to the Trash and empty the Trash. Then download and install a new version of the App from www.bluesound.com/downloads. By not finding teh Player, i thought you meant the App launched but the Player was not being displayed.
  • Julian Redding
    I'd previously tried the steps you advise and it made no difference. I've also tried one further time with no success. I did try a wired connection from my Macbook to the router and the controller works fine. So definitely a wireless problem (but unable to grab a log as it doesn't initially find and connect to the speaker). Any further thoughts?
    I have escalated your issue. We will be in touch.
  • George du Chesne
    I have the same problem and the same screen with NODE 2i on Mac Mojave 10.14.6
    BluOS controller app is 3.4.9
    BluOS from my Samsung does not work either
    I just received my NODE, please provide a solution, I'm seriously thinking sending the unit back to amazon
    Thanks in advance
    George
    Hi George
    We will be in touch via e-mail
  • Mark
    I have exactly the same problem with Mojave 10.14.5-- everything worked "fine"- I went on holiday and came back and nothing will now connect- I am an old customer and have been so frustrated for many years with Bluesound connectively issues- I know all the tricks and have tried all the tricks but nothing at all is working. I have about $5000 worth of useless Bluesound equipment which I cannot use. I lodged a customer request 3 days ago and have not been contacted - this is just impossible-
    Mark
