Which cable to use to connect TV to Powernode 2i
BeantwortetHello dear community.
I want to hook up my Samsung smart TV with my powernode 2i to play through my Monitor audio speakers.
Which cable to I have to use to connect both devices as the Powernode 2i does NOT have an optical in? Does something like Optical to 3.5mm cable work?
Thanks for the help
Geoffrey
Hi Geoffrey
In the POWERNODE 2i packaging you should have an optical/3.5 mm connector clip to attach to a standard optical cable and plug into the 3.5 mm optical/analogue dual in port. It looks something like this;
If you threw it out with the packaging, you can find them from either your Bluesound Reseller or online some where in the $3-5 range (US).
