Bluesound Network and VLANS
    Hi Mark
    Apps on one network and Players on another (VLAN or otherwise) will never work as mDNS (multicast) is not routable by design, but many a CCNA have tried. If any have been successful we have not heard the magic port mix yet - but looking forward if anyone does figure it out.
    Without The Internet, you are correct, no Music Services such as Spotify or TIDAL, no software update notifications AND if you have VAULT, no automatic metadata identification and additions when ripping a CD...    ...but it does work. If you are closing the Internet because you are concerned about security, well we are too and lock down your Players as best we can on that front.
  • Mark Mason
    Ok thanks, this is what I had heard.  I'll put everything on one for now.
  • Anton Strandh
    Hi! It's now possible to route multicast between different vlans, at least in my Ubiquity Unifi-setup.
    What ports does Node 2i use to communicate within the network? For all local services to work.
