Bluesound node 2i Android, won't allow permissions
BeantwortetBluOS takes me to a screen in my android tablet that says "Can write system settings", but it is grey out and wont let me give permission?
Hi Bruce
Please fully uninstall the BluOS App from your tablet via Android Settings. Power down your tablet and restart it. Once completed, download a new fresh version of the App from Google Play and reinstall it.
If the problem persists, please e-mail us at support@bluesound.com as we are going to want more specifics such as the make and model of your tablet and which Android version you are using.
I have the same issue.. Tried 2 different phones.. Installed Uninstaller restarted.. Only msg I get is location permission is needed to scan for wifi with bluos app.
I even manually gave the bluos full permissions but still will not connect1
