Can't access Vault from Wired Connection
4 Kommentare
    Hi Tom
    It would be something in your laptop and network settings... Was that wired connection going back to the same network?
  • Tom Breakfield
    I would have thought so - but I will see. I guess the simple fix is to unplug the network cable when I need to access the Vault 2i - obviously though, it is on my end and not your fault. Strange. Thanks!
  • Gary B. Freidman
    A typical example of the mediocre support from a company with such great products.
    -1
    Hi Gary
    I'm sorry you came to that conclusion. Is there something I can help you with? Feel free to post here or e-mail us at support@bluesound.com or select Help, Send Support Request in the App so we can also receive the log file form your VAULT.
