Alarm function not working properly on my Vault
BeantwortetMy alarm function not working properly on Vault. It used to be when I picked “continue playing from the queue, or worked just fine. Now, all it does is play the annoying alarm. It sometimes works pay shed I pick a playlist or preset, but really would like to use the continue playing option so my queue doesn’t get cluttered. Your assistance with this matter would be greatly appreciated. Thanks.
Hi Niro
Please select Settings, Send Support Request in the app so we can review your log file and see why the Alarm is not resuming the current Play Queue.
Request sent per your request Tony. Hope this issue can resolved quickly!
My technical support request was deleted, so I’m back here. I tried using Tidal tracks, alarm still sounding. I tried using WAV files from my Vault, alarm still there. I was asked to remove alarm, but have no idea hose to do that. Not very happy so far.
Your request is still open. You are in good hands with our Sr Support Team.
Thanks Tony
5 Kommentare
