Crackling sound from Node Icon via USB
BeantwortetI have now three different DAC:s at home and the random crackling noise is there on each an everyone of them when I stream from Icon to DAC via USB. The question is if it it a general fault or just my Node Icon. Would be interesting to hear if someone else have the same error
//Fredrik
Hi Fredrik
I believe I answered this question multiple times for you - but in reviewing our Community, I see you have deleted your thread where I answered this.. I have a copy of that answer though.
Review your DAC documentation to ensure it does not need a driver and designed specifically for a PC.
Here is my previous response;Thank you, Frederik
From your third-party DAC's website;USB Audio Class 2 (up to 32-bit/384kHz)**Driver Installation RequiredThis output is designed for a PC and not proper audio component playback. Please continue to use COAX, TOSLink or the analogue output of the NODE ICONs dual ESS Sabre ES9039Q2M DACs.
We consider the matter closed.
