Is there a difference between the streamer component of a Nano vs. Icon or Node?
    Permanently deleted user
    As you are bypassing the DAC in the NODE or any other Bluesound device by using the digital output I suspect you will not find much if any difference.
  • Alan de Vries
    Thanks!
