Track order incorrect
5 Kommentare
    Cliff McKnight
    I've now done a rebuild which seems to have sorted it and I've re-read the article and think I now understand it.
    Thanks for your help,
    Cliff
  • Permanently deleted user
    By any chance you haven’t changed the sorting order?
    https://support.bluos.net/hc/en-us/articles/360000058107-How-do-I-browse-or-sort-songs-and-albums-in-the-BluOS-Controller-App
  • Cliff McKnight
    I haven't changed the sorting order but if I look at the album via
    artist  > album    the tracks are in alphabetical order.
    If I look at the album via
    album > title   the tracks are in the correct order.
    Since the artist in this case starts with an E and the album title starts with TI (so after all the The albums) there's a big overhead in finding it.
    I couldn't see where in the sorting order I could correct it but I'd be happy to be pointed in the right direction.
    Thanks,  Cliff (iPhone running latest OS)
    Did you use rebuild or reindex? In the iOS / Android BluOS App please select Settings, Help & Support, Diagnostics, Rebuild Index from the home page. This will purge and recreate a Music Library of your library.
    When viewing you can change the sort order, please check the doc I linked to.
    Probably best to contact support, in the BluOS App please select Settings, Send Support Request, the Bluesound Support Crew will be able review the log file and take a closer look.
  • Cliff McKnight
    I did a Reindex because I know a Rebuild takes quite a while, given the size of my library. I'll do a Rebuild and go watch some TV :-)
