Wrong Qobuz track played in multi disc
6 Kommentare
    Hi Deaste
    I see you have since spoken with our Support Crew about the matter. Our Quality Assurance has been able to replicate this. If you select the tracks directly, it appears to work. We hope to publish a fix in the near future once our Product Development Team can find the root cause of the issue.
    Thanks for bringing it to our attention and we do apologise for the inconvenience.
  • Marek Gierlinski
    Tony,
    I raised this issue 5 months ago
    https://support1.bluesound.com/hc/en-us/community/posts/27998885990039-Issues-with-some-long-albums
    and it is still not solved. Any chances you can fix it rather soon than later?
    Marek
  • deaste
    Solved after July 2025 firmware update.
  • Marek Gierlinski
    Alas, it has not been fixed. Check the album below. If you scroll down to the last entry (symphony No. 10) and tap it, it plays symphony No. 8, first movement. If you tap the first movement of No. 8, it plays movement IV of symphony No. 7. And so on. It is still wrong.
    Using Android app version 4.10.0, BlueOS version 4.10.11. Android 15.
  • deaste
    Yes, you're right.
    I tested Mahler: Complete Symphonies
    Symphonieorchester Des Bayerischen Rundfunks • Rafael Kubelik
    and now that is OK
    but there is something still wrong with Mahler: Symphonies Nos. 1-9
    SWR Sinfonieorchester des Südwestrundfunks
  • deaste
    I've tried several multi disc releases after September firmware update and everything now seems Ok. The same releases are ok using Qobuz Connect.
