Wireless Rear Speaker w/ Powernode Icon + Flex2i
BeantwortetHi, I already have a great integrated amplifier with front L+R speakers and subwoofer. I plan on adding an Icon to my system for streaming. If I buy two additional Flex2i speakers, can I use the Icon to use all my existing system along with the two Flex2I speakers as the rear speakers?
Thanks in advance.
Unfortunately not you need an amplified Bluesound device for the front, then you can use Flexes for the rear channels.
Thank you for the response!
