Node Icon Standby after 15 minutes and it takes 5 seconds to play any sound?
4 Kommentare
    Mark T.
    Sr. Support Crew Member
    Hi Jappa,
    The 5 second delay that you are experiencing might be from your amplifier starting up. If you need support from this, please reach out to us by sending us a support request using the BluOS app.
    However, I have forwarded your feedback to our quality assurance and development team for future update consideration.
  • Jappa
    Hello Mark,
    No. My amplifier is always on (manually). And not on a 'trigger' (which the Node Icon provides).
    Also: I was using the Node N132 (without any 'standby' issue) and swapped it with my new Node Icon (without Standby-options, with Standby-issues).
    Anyway: this morning I thought: new day, fresh start? Let's try to RESET the Icon, do the setup and see if it changes anything about inputs and Standby-functioning.
    Easy, perfect textbook setup from WiFi only. I have had my share of problems to setup a Bluesound device in the past (Powernode, Node N130, Powernode Edge, Pulse M). Today: perfect!
    Instead of Optical input from my LG OLED to Icon, I am now using HDMI-ARC.
    Computer HDMI goes to LG OLED, which delivers sound through HDMI-ARC to Node Icon. Works perfectly.
    Playing music from PC. Pause and after 15 minutes the Icon goes in Standby.
    Press Play and after 5 seconds music is heard (missing the first 4 or 5 seconds).
    Windows system-sounds will wake Icon from Standby but the sounds are lost (they are usally less then 5 seconds).
    A few thoughts:
    - I can not believe there is NO OPTION for Standby (settings). Every computer has options for system and video-standby. A time-setting is the most basic option, next to Standby ON/OFF.
    - The name 'NODE' has a special, relevant meaning, right? How can Node Icon be a 'Node'? It disrupts everything connected to it after 15 minutes of 'silence'.
    - I will always loose 4 or 5 seconds of sound when the Icon comes out of standby (switching to TV or continu/start Playback music from computer).
    - Windows systemsounds will be lost. (If 2 systemsounds are produced within 15 minutes, okay, then I may hear one systemsound...)
    Saving Energy is great! But having NO CONTROL over it?
    And having to learn how to 'properly' handle the Node Icon to play music? First turn ON the Icon, next start playing the music? I am not good at learning tricks and workarounds... Maybe it's my age (almost 70) :)
    Just an idea
    Maybe the BluOS team can make some creative use of the 'Sleep Timer' and make a 'Standby Timer'?
  • John Petticrew
    I’m having the same problem with no solution to be found. Just received Icon and while using computer if I walk away to use the bathroom and grab a drink and or snack and come back the node is off along with my amps. So then I have to force a sound then wait for it to turn back on along with my amps. I don’t think it’s good for my amps to be turning off and on so much, they have internal switches and completely shut down. I don’t know. Very stupid we can’t change it to half hour or 45 minutes.
  • Jappa
    Hello John,
    I am not sure if this topic is 'monitored'. It has been 'answered'...
    Maybe best if you start a new topic and refer to this topic.
    Even better: start a support-request from Bluos App (Help - Send Support Request)
    You have the same problem, means the Bluesound development team did not find a solution or did not implement it (yet).
    All I can contribute at this point: Did you try removing the Trigger (cable) to your Amplifier (and start the amplifier manually)? This to be sure that your Amplifier is not causing an extra delay.
    I returned my Node Icon (I had a generous 30-day return-window) and reinstalled my old Node (N130). Very happy with it, never miss a Windows sound, and no action required to hear any Audio from the computer.
