Node 132 and Dirac - Storage of different settings possible?
    You can store up to 5 DIRAC filters in BluOS. There is no reason why some of those filters may be using one set of measurements and others using an other.
    If you run into problems and can drop our Support Crew DIRAC Specialists a note at support@bluesound.com and they can at least show you how quick and easy it is to swap out saved stored filters on your DIRAC account using the DIRAC App on your Phone or Tablet.
    Though DIRAC is new to Bluesound, at has been part of BluOS for many years thanks to our friends down the hall at NAD Electronics.
  • Heinz RB
    Thank you very much, Tony! Your first sentence of your reply cleared it up for me, that's good news. But to be honest, I didn't understand your second sentence:
    „ There is no reason why some of those filters may be using one set of measurements and others using an other.“
    I have to say that I'm not a native English speaker but I also had it translated with deepl and I don't understand the message.
    Anyway, thanks a lot.
