HUM in speakers when connecting Node Icon using XLR - what is the Node Icon XLR pinout?
4 Kommentare
    Permanently deleted user
    I don’t have an ICON but understand it uses a floating ground on XLR, try grounding the ICON to the speaker by adding a phono lead between them. Use one of the phono analogue outs on the ICON to an analogue in on the speaker.
    Alternatively just use any other output rather than XLR.
  • Paul Granone
    Hi Seppi,
    The RCA out connected lowers the volume of the hum.  But the hum is still there.   So that does not solve the hum issue.
  • Permanently deleted user
    If the speakers have an optical input then that would be the best as then both devices are electrically isolated. If you are still having issue then in the BluOS App please select Settings, Send Support Request, so the Bluesound Support Crew can review the log file and take a closer look.
  • Vaidas
    I have totally same issue. Upgraded from Wiim Ultra and tried to use good XLR cables, but unfortunately they work as antenas, because they are no grounded on Icon side, what a shame for such a price. If you connect via RCA it is all good. Just looks like Bluesound engineers forgot that Icon can be connected to active speakers instead of an amp. Same issue that you cannot group Icon to 4.1 cinema, while with Wiim you can.
