DALI BluOS NPM-1 Bluesound VS DALI BluOS NPM-2i Bluesound
BeantwortetHello
I've tried to search and find the differences between the
DALI BluOS NPM-1 Bluesound and DALI BluOS NPM-2i Bluesound.
so far I'm only able to find that the NPM-2i are able to add airplay.
Is the airplay feature the only noticsable feature difference between the two version?
- Thank Jakob
Hi Jakob,
Yes, the only difference between the two is that the NPM 2i have Airplay and two-way Bluetooth connection.
For added support, please reach out to DALI support.
