Node doesn't sequence through tracks
BeantwortetNode doesn't sequence through tracks but Vault does. However, if I group the Node and Vault, it will no longer sequence. Doesn't matter if Node is controlled by Android or Windows. Final note: Track plays repetitively.
Hi Bruce,
Please makes sure that repeat button in BluOS is NOT selected - https://support.bluos.net/hc/en-us/articles/360000216748.
If you are still experiencing issues, please send us support request using the BluOS app. In the BluOS app >> Settings >> Help >> Send Support Requset.
