    Permanently deleted user
    You can connect the VAULT’s share using a PC or Mac and edit the metadata, I use a Mac and use some software called Bliss to edit tags and artwork but there are editors available for many platforms. Bluesound rely on external databases for the metadata when CDs are ripped and occasionally the information is incorrect but quite easy to fix.
    Once edited you need to run a rebuild index to reflect the changes in the BluOS App
