Streaming difference or not?
BeantwortetIs the streaming section of all 3 new models basically the same? Using external DAC.
All BluOS Players offer a full range of Streaming Services and run identical software.
All our passive component products offer the ability to use the onboard DAC or bypass the onboard DAC and use an external digital out.
Thanks, I think the answer is Yes although it can also be Yes, but ... Same software can be implemented on different hardware, which can impact the sound. If not too much to ask, is the hardware component specific strictly to streaming services all the same? Thanks again
No 'But's
Got it, thanks. Much appreciated!
4 Kommentare
