Digital Volume Bit Stripping?
    Permanently deleted user
    There are no audible bits discarded when using variable volume control, internally the DAC(s) are processing in a 32bit environment which give you the room / overhead to adjust the volume with no impact.
  • Edwin
    Thanks for the clarification, Seppi. When you say "no audible bits discarded" does that mean bits are being discarded, but they are inaudible, or that no bits are being discarded? If a 32bit environment allows for full range of attenuation without losing any bits...that would be a game changer...
  • Permanently deleted user
    To reduce a digital signal you have to remove something, these are removed in the 32bit environment. I don’t have the full technical details but someone from Sonos might be able o chime in.
