Bluesound Pulse Subwoofer with Powernode
BeantwortetCan a Pulse Subwoofer be connected wirelessly to a Powernode? I don't have the ability to connect the coaxial out to a powered Subwoofer.
Hi Bruce,
If you are referring to Bluesound PULSE SUB+, then yes you can.
To get 1:1 assistance, please reach out to our support crew using by using the BluOS app. In the BluOS app, BluOS >> Help >> Send Support Request.
Thanks for #LivingHiFi -
What about the Gen1 Bluesound Pulse Sub? Can that too be paired to play in sync wirelessly with the Powernode with 2 x wired speakers?
